2024-01-20 5:45 AM
Hi team.
I want to drive BLDC motor in 6-step method like below figure.
Is there any sample code for this method?
2024-03-29 1:01 AM
Hi.
I don't find a sample code.
But AN4776:General-purpose timer cookbook for STM32 microcontrollers document will help you.
Read the page 64, Synoptic schema of two complementary N pulses waveform generation
example.
2024-03-27 8:38 AM
I want to do the same thing.
Do you find a solution? Do you have a sample code?
2024-03-29 1:01 AM
Hi.
example.
