2023-07-11 02:07 AM
Can STEVAL-ESC002V1 be applied in a electronics of quadcopter? For example, is it possible to connect to betaflight FCU or Pixhawk?
2023-09-07 05:24 AM
Hello @LukeBaek
We would like to sincerely apologize for the delay in replying to your post.
If your point is still pertinent, You can find the documentation to use the STEVAL-ESC002V1 at this link : https://www.st.com/resource/en/user_manual/um2518-getting-started-with-the-stevalesc002v1-electronic-speed-controller-reference-design-stmicroelectronics.pdf.
It looks like it's possible to use this board to control a motor with an incoming PWM signal, that signal could be coming from your flight controller.
2023-09-07 05:24 AM
Hello @LukeBaek
