Is it possible to use Motor Profiler with Nucleo-L452RE-P?
Rassom
I tried Motor Profiler by selecting Nucleo-L452RE and X-NUCLEO-IHM08M1. However, the actual MCU board is Nucleo-L452RE-P. The profiler first updated the firmware in L452RE but when it comes to verifying the firmware, it throws the attached error. 0693W00000Hnt8uQAB.png
1 REPLY 1
Laurent Ca...
Lead II
Dear @Rassom​
Sorry for the late answer.
Do you have still this problem to solve?
And just in case, if not, do not hesitate to share the final solution you found. Thanks by advance.
Best regards
