How to change the parameter  Minimum  frequency  in main.c
methee_c
Hi All,
I need to change parameter  Minimum  frequency  "MIN_FREQUENCY_TH "  by main.c
not chage  in acim_vf_parameters.h
Please help me for advice.
BR,
Methee
Guru
#define MIN_FREQUENCY_TH 42
Maybe.
4 REPLIES 4
Sarra.S
Hello @methee_c,
Some context maybe?
Guru
Maybe.
Dear  TDK,
Ok, now i can setting but can't set variable to float  function need to constant  only
BR,
Methee
Dear  sarra.S,
Thanks you,
Ok, now i can setting  in main.c but can't set variable to float  function need to constant  float only.
BR,
Methee
