2024-08-07 02:16 AM
Hi, I recently bought a STEVAL-SPIN3204 and now i want to connect it with my PC, i connected it with the USB cable, selected an example project for this device and clicked on connect, but there comes always the error message, connection failed. What did I do wrong or have i forgotten? Here you can see a picture of the interface:
I also checked the baudrate and everything.
2024-08-08 02:52 AM
Hello Christian3,
Could you please be more specific with your procedure ? What version of the MCSDK are you using ? Have you considered upgrading to our latest (6.3.0) version ? Which IDE have you used for flashing the code, and which version ?
When you say that you checked the baudrate and everything, could you be more precise ? Are you sure the COM port is the right one ?
2024-08-08 02:52 AM
Hello Christian3,
2024-10-01 06:37 AM
I wrote you an email!
