2024-09-26 12:25 AM
Hi All,
I am a newbie in motor control. I am having a X-NUCLEO-IHM08M1 board with me I came to know that it supports both sensored as well as sensorless motors, but could'nt find a sensord motor that is compatible with the board but found one sensor less motor named BR-2804. Can anyone suggest a motor that comes with hall effect sensor which is compatible with the board. If motor does not come with any sensor in it, can we add external sensors to it, If yes can anyone suggest a sensor too.
With regards,
Tashi George
2024-09-30 8:54 AM
Hello @tashigeorge,
The list of available motor on Workbench tool is not limited.
Using MC motor profiler tool (please refer to User Manual documentation available through "Workbench tool">About>Documentations>Documentation>"User manual" tab, "Motor Profiler Application Note" link), you can profile your motor and use it on Motor Control workbench tool.
2024-09-30 8:54 AM
Hello @tashigeorge,
2024-09-30 9:28 PM
Thank you.
