[Bug report] MCM_Modulus does not work for negative alpha values when using CORDIC
Sune Jensen
[VERSION]: 6.3.1
[TOOL]: Firmware
[DETAILS]:
The implementation of MCM_Modulus defined in mc_math.h calls the CORDIC peripheral like this:
LL_CORDIC_WriteData(CORDIC, (((uint32_t)beta << 16U) | (uint32_t)alpha));
This works fine as long as alpha is positive. However, when converting a negative alpha from int16_t to uint32_t the upper 16 bits will all be '1', hence beta is overwritten.
[PROPOSED SOLUTION]:
Mask the upper bits of alpha before combining with beta.
LL_CORDIC_WriteData(CORDIC, (((uint32_t)beta << 16U) | ((uint32_t)alpha & 0xFFFF)));
Note: Images are attached that show calculated phase current using the wrong and the correct conversions respectively.
GMA
Hello @Sune Jensen,
Thank you for your problem report. A ticket has been entered on our side and notification will be done once corrected in further delivery.
If you agree with the answer, please accept it by clicking on 'Accept as solution'.
Best regards.
GMA
1 REPLY 1
GMA
Hello @Sune Jensen,
Best regards.
GMA
