2023-10-11 01:39 PM
Hi all,
I need to insert fault on upper key of the driver. In order to achive this Im changing dedicated TIM1 output to Input to output low. After inserting fault motor stops. Is it possible to achive this? Could someone explain what Im doing wrong. Thanks on advance.
Dawid
2023-10-12 01:42 AM - edited 2023-10-12 01:55 AM
@Dawid Żądło Hello ,
Can you give me more details please?
What do you mean by "upper key" ?
Do you want to manually trigger an error and use the Timer1 break input as is currently done for Over current protection ?
