2021-11-30 8:39 AM
Hi everyone,
I try to get my motor control setup working:
Hardware: Nucleo L476RG with ihm16m1 expansion board, motor Gart ML5008 330KV, 24V power supply
I am trying to get my BLDC motor to spin by using motor control FOC library.
I generated example project with Motor control workbench and managed to run it but the motor does not spin.
My questions:
Is this hardware even compatible?
Are there any good tutorials or example projects to begin with?
Thanks in advance.
2021-12-20 11:02 PM
Dear @FFedo.1
Sorry for the late answer.
Do you have still this problem to solve?
And just in case, if not, do not hesitate to share the final solution you found. Thanks by advance.
Best regards
2024-03-12 2:03 AM
Hi
Can you please answer his question. Are these boards compatible ?
Younes
