ACIM support - which version to use?
2025-02-20 4:40 AM
On the wiki page:
https://wiki.st.com/stm32mcu/wiki/STM32MotorControl:SDK_AC_induction_motor
It says:
""This article applies to the 5.Y.* versions series of the X-CUBE-MCSDK. ACIM motors are not supported in older versions of the X-CUBE-MCSDK (v5.4.* and before). They are not supported yet in X-CUBE-MCSDK versions 6.*."
However, the latest v5 version I can download is 5.4.8.
So, it appears that I would need to use version 6 to compile the examples, while full support comes later?
2025-03-06 8:49 AM
Hello @lamare,
Wiki page isn’t up to date (thank you for the report).
Two ACIM examples are available on the latest X-CUBE-MCSDK-6 workbench available here.
Loading ACIM example of Motor Control workbench, it’s possible to change parameters and generate a project.
Best regards.
GMA
2025-03-06 8:49 AM
Hello @lamare,
Best regards.
GMA
