2024-02-11 06:02 AM
Hi
I m currently implementing a project using MC Workbench software. There is a DAC Functionality subblock in the COntrol Unit block. Can you tell me what is this block and why it uses two mcu pins as DAC ? For users which designing a custom board, what should they do with these pins ?
Thank you
2024-02-12 01:35 AM
As mentioned on left hand box, you can use these Digital to Analog Converter outputs for:
- "Debug" purpose displaying Ia and Ib currents with a scope connected to PC8 and PC9 pins.
- "OCP" Over Current Protection purpose by generating a voltage level to be used in a comparator.
You can also set it to "Not used" to disable it.
Please go to Firmware documentation for more details.
2024-02-12 01:35 AM
