A question about 6-step for X-NUCLEO-IHM16M1
wcc689653
Visitor
  • MC Workbench generates a 6 step_sensless code for the following board:
  • Type: 6-Step / Voltage Mode
  • Control: NUCLEO-G431RB
  • Power: X-NUCLEO-IHM16M1
  • Motor: GimBal GBM2804H-100T
  • Code: pwmc-3pwm.c in middle-ware
      Question: In each step, it looks like PWM-ch1 (High-side MOSFET)  and  Enable pin( Low-side MOSFET) turn on at the same step?  For example,in Case STEP_1, both "PWM_ch1(for U)"  and "pwm-en-U-pin" are set to high, why it will not cause short circuit?
/* pwmc-3pwm.c  6 steps DC brushless motor
/*_weak void ThreePwm_LoadNextStep( PWMC_ThreePwm_Handle_t * pHandle, int16_t Direction )*/
/* 372-442*/
 /* standard configuration */
  else
    if (pHandle->DemagCounter >= pHandle->_Super.DemagCounterThreshold )
      pHandle->FastDemagUpdated = true;
      ThreePwm_ResetOCPolarity(pHandle);
      LL_TIM_GenerateEvent_COM( TIMx );
    switch ( pHandle->_Super.NextStep )
    case STEP_1:
        LL_TIM_OC_SetCompareCH1 ( TIMx, (uint32_t)pHandle->_Super.CntPh );
        LL_TIM_OC_SetCompareCH2 ( TIMx, 0 );
        LL_TIM_OC_SetCompareCH3 ( TIMx, 0 );
        LL_GPIO_ResetOutputPin( pHandle->pParams_str->pwm_en_w_port, pHandle->pParams_str->pwm_en_w_pin );
        LL_GPIO_SetOutputPin( pHandle->pParams_str->pwm_en_u_port, pHandle->pParams_str->pwm_en_u_pin );
        LL_GPIO_SetOutputPin( pHandle->pParams_str->pwm_en_v_port, pHandle->pParams_str->pwm_en_v_pin );
      break;
    case STEP_2:
        LL_GPIO_ResetOutputPin( pHandle->pParams_str->pwm_en_v_port, pHandle->pParams_str->pwm_en_v_pin );
        LL_GPIO_SetOutputPin( pHandle->pParams_str->pwm_en_w_port, pHandle->pParams_str->pwm_en_w_pin );
      break;
    case STEP_3:
        LL_TIM_OC_SetCompareCH1 ( TIMx, 0 );
        LL_TIM_OC_SetCompareCH2 ( TIMx, (uint32_t)pHandle->_Super.CntPh );
        LL_GPIO_ResetOutputPin( pHandle->pParams_str->pwm_en_u_port, pHandle->pParams_str->pwm_en_u_pin );
      break;
    case STEP_4:
      break;
    case STEP_5:
        LL_TIM_OC_SetCompareCH3 ( TIMx, (uint32_t)pHandle->_Super.CntPh );
      break;
    case STEP_6:
      break;
0 REPLIES 0
