X-CUBE-DPOWER STM32G474 - Software Download Issue
waaizkhan
Hi ,
I want to install X-CUBE-DPOWER for stm32g474 board but this message appears This software is not available for download.
Can anyone help me solve this problem?
Kind Regards
STea
Hello @waaizkhan ,
I'm able to Add the X-cube-Dpower to a CubeMX using these steps:
1- download the package from St.com website from this link
2- open cubeMX project and the select software packs manage software packs
3-select the from Local option and select the downloaded .pack file
4-select software packs component selector and browse to the X-cube-Dpower section and select you desired functionalities it should know appear under middleware and software packs section in MX
hope this helps you.
BR
3 REPLIES 3
STea
Hello @waaizkhan ,
BR
Are we sure the issue isn't due to regional lockout?
Are you able to inspect individual user failure logs as to why it wasn't deemed available?
Thanks a lot i have downloaded and install it.
