2018-07-03 08:56 AM
Hi all:
STM32Cube_FW_H7_V1.2.0 ethernet sample is using DHCP, I want use static IP address. So I change the DHCP definition to 0 in lwipopts.h.
&sharpdefine LWIP_DHCP 0
After comple the code and download to board, but I can not ping to board. What is wrong?
Thanks.
#stm32h7-ethernet #stm32hSolved! Go to Solution.
2018-10-29 08:03 AM
I have been debugging the mentioned topic for 4 days.
When I have considered the CubeMX generated code is out of luck I moved to thex example shipped with the STM32H7 pack of the cube:
LwIP_HTTP_Server_Netconn_RTOS
It took me a while to get it compiled under Atollic, and then I have realized that the board receieves packets, responds to ARP queries, but does not sends ICMP ACKs.
By further debugging it turned out that sometimes it ACKs the pings, but most of the times it just relies the ping ICMP packet with the same source/dest address as it recieves from the host.
First i thought that it is this LwIP bug, but it turned out to be different:
https://savannah.nongnu.org/bugs/?func=detailitem&item_id=54669
After reading through this:
https://community.st.com/s/article/FAQ-Ethernet-not-working-on-STM32H7x3
I have realized that the MPU config in the example differs from the attached one.
After using the config from the FAQ the ping requests working just fine...
It took me 4 days to figure this out...
2018-10-29 08:03 AM
2018-10-29 08:03 AM
2019-01-03 01:05 AM
Hi, I made a new example project using STM32Cube_FW_H7_V1.3.0. You can find it here
https://github.com/MX-Master/STM32H7_Nucleo-H743ZI_Ethernet_LwIP
This project uses LwIP stack without RTOS. There is a HTTPD (web server) example too.
Configuration info can be found in the README.
2019-01-03 01:16 AM
Many thanks for putting together this repo!
I have missed the settings of the GPIO slew rates!
