2020-04-02 8:09 AM
i have tried numerous time to add the file path for FatFS files in my project to makeFile, touch designer wont flash board because icant file the .Fatfs,h file.
i was advised by ST employee to add file path to the MakeFile , not being a software engineer i dont know how its written, below is the location where it goes i have it highlighted.
i cant find info anywhere that relates to this makefile format
thanks
Barry
2020-04-02 8:37 AM
I'm an electronics engineer...
Attach the actual makefile, not pictures of it.
2020-04-02 9:54 AM
2020-04-02 10:15 AM
I too have a degree in electronics.
#keep framework include and source out of this mess! :)
include_paths := $(library_includes) \
$(foreach comp, $(all_components), $(comp)/include) \
$(foreach comp, $(cubemx_components), $(comp)/Inc) \
$(foreach comp, $(touchgfx_generator_components), $(comp)/generated) \
$(framework_includes) \
$(source_Middlewares_paths) \
$(touchgfx_generator_components)\
$(os_path)/UseCanvassBuffer_Add_SDMMC/FATFS/App/fatfs.c
You are supposed to add a path to the directory (in modern micro$oft lingo, folder) where fatfs.h in question is located, not complete path to fatfs.c file.
You surely can navigate the directory structure on your PC.
2020-04-02 10:26 AM
Hi Jan,
thank you getting back to me
the fatFS.h file is in the folder as above, which I also tried, my problem is how to include ie what comes before it $( ??????) what is required in here , screen shot above was from one of attempts , and yes I can navigate the directory, just the root folder required not complete path
2020-04-02 1:46 PM
If you can navigate the path, just put it there as is. (of course replace all backslashes to /). See if this works.
-- pa
