UART communication between Raspberry Pi 4 and stm32f411re
Hi, i want the communication between stm32f411re board and raspberry pi 4. i tried to do with uart2 through USB cable it is working fine. but sometimes it is not able to communicate properly. there is a delay while communicating sometimes. will i2c or spi communication works with USB cable to communicate. which is better and i want the one efficient to work as i want both ways communication.
suhfiBest answer
Okay sure, the problem is with the delay in the communication of stm32 Nucleo board and raspberry pi through UART. but later i have understood that the delay is not with the communication but with the motors drivers and working of that. Thank you for your time.
Andrew Neil
There no inherent reason why that should happen with a UART connection.
You need to find out what's causing this delay - it must be something elsewhere in your system.
Changing to some other transport won't fix that.
Have you tried using the Raspberry Pi's hardware UART ?
PS:
Please give more details of that.
I assume you mean a USB-to-UART cable/adaptor somewhere?
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
suhfiAuthor
No, i didn't do the communication by connecting the gpio pins, but from the usb cable. there is a delay for sure. i didn't mention any delay with that, then why am i facing delay with the comunication.
Andrew Neil
Again, you need to give more details.
How, exactly, are you making this USB connection?
Show a schematic.
Post photographs.
What, exactly, is the "stm32f411re board" you are using?
Is it still the same as this:
https://community.st.com/t5/stm32-mcus-products/communication-between-nucleo-f411re-and-raspberry-pi-using-st/m-p/721443
mƎALLEm
Related to this thread: https://community.st.com/t5/stm32-mcus-products/communication-between-nucleo-f411re-and-raspberry-pi-using-st/td-p/721443
Need to clarify this statement. From which side? STM32 delays the transmit or Raspberry-Pi?
Andrew Neil
Indeed.
@suhfi Also, how much of a delay is it?
How do you observe this delay?
Andrew Neil
suhfiAuthor
Thank you for the replies, i did solve the problem.
Andrew Neil
Great - so, for the benefit of future readers, what was the problem?
Please describe how you solved it, and then mark that as the solution:
https://community.st.com/t5/community-guidelines/help-others-to-solve-their-issues/ta-p/575256
suhfiAuthorBest answer
