2020-08-05 3:14 AM
I'm trying STM32L05x embedded bootloader - Read Memory command via UART.
I can read flash memory (e.g. address start by 0x0800_0000), but when I try to read SRAM ( start by 0x2000_0000) , it always return NACK.
Is it not possible to read SRAM via bootloader?
2020-08-05 4:37 AM
2020-08-05 4:37 AM
2020-08-05 6:52 AM
You could perhaps write code residing higher in RAM, and execute that to perform different modes of access, external memory or whatever.
2020-08-05 7:25 PM
Thanks a lot !
