STM32f7 fatfs f_write returns FR_DISK_ERR when passing a pointer to a mail queue object.
JArap.1
I'm trying to use FreeRTOS to write ADC data to SD card on the STM32F7 and I'm using V1 of the CMSIS-RTOS API.
I'm trying to use mail queues and I have a struct that holds an array.
    typedef struct
         uint16_t data[2048];
    } ADC_DATA;
on the ADC half/Full complete interrupts, I add the data to the queue and I have a consumer task that writes this data to the sd card. My issue is in my Consumer Task, I have to do a memcpy to another array and then write the contents of that array to the sd card
void vConsumer(void const * argument)
	ADC_DATA *rx_data;
	for(;;)
		writeEvent = osMailGet(adcDataMailId, osWaitForever);
		if(writeEvent.status == osEventMail)
			// write Data to SD
			 rx_data =  writeEvent.value.p;
			 memcpy(sd_buff, rx_data->data, sizeof(sd_buff));
			 if(wav_write_result == FR_OK)
				 if( f_write(&wavFile, (uint8_t *)sd_buff, SD_WRITE_BUF_SIZE, (void*)&bytes_written) == FR_OK)
						file_size+=bytes_written;
			osMailFree(adcDataMailId, rx_data);
This works as intended but if I try to change this line to
f_write(&wavFile, (uint8_t *)rx_data->data, SD_WRITE_BUF_SIZE, (void*)&bytes_written) == FR_OK)
f_write returns FR_DISK_ERR. Can anyone help shine a light on why this happens, I feel like the extra memcpy is useless and you should just be able to pass the pointer to the queue straight to f_write.
1 REPLY 1
DMA would have memory alignment and memory region dependencies.
Watch for cache coherency issues.
Perhaps look at the addresses in failing, vs non-failing cases.
