STM32CubeMX and Discovery STM32F407VG Timer8 PWM
Options
‎2016-05-20 06:41 AM
Posted on May 20, 2016 at 15:41
I am trying to configure Timer 8 to generate a PWM signal on either PC8 or PC9 on the Discovery board. I have used STM32Cube to generate the initialization code. I have been unable to get this configuration to generate any output. The ISR associated with Timer8 runs, but there is no PWM output.
I have successfully configured Timer 3 to generate PWM on these pins. I have compared the pin configurations and timer configurations between Timer 3 and Timer 8 and can find no difference except or the appropriate gpio alternate function value. Has anyone been able to get the PWM working on Timer8? Thank you, Eric Nystrom #je-ne-l'aime-cube #!android #no-hablo-hal
Labels:
- Labels:
STM32Cube MCU Packages
2 REPLIES 2
Options
‎2016-05-20 10:56 AM
Posted on May 20, 2016 at 19:56
Well they do work, both TIM1 and TIM8 are advanced timers, they more more initialization parameters and PWM Output must be explicitly enabled.
Options
‎2016-05-20 03:15 PM
Posted on May 21, 2016 at 00:15
Thanks for the hint. I finally got it working. I was missing setting the MOE bit in the BDTR.
TIM8->BDTR |= TIM_BDTR_MOE; Eric Nystrom
