2024-11-11 6:30 AM - edited 2024-11-12 10:00 PM
2024-11-12 6:24 AM
I apologize for not seeing this answer.
Anyway, I couldn't explain myself. I guess it's because I'm an amateur.
I request that you delete the topic.
The topic has started to go to irrelevant places.
I'll work on the topics a little more and try to write the program again.
Note: Please delete the topic.
2024-11-12 9:12 AM
Be beginer isnt problem, now after all your writes maybe i understand , what you name outputs and inputs, but still not clean. You still not show code where you stuck. Showed delays is little hardcore, but we need see code where is used...
And around yor leds: you create multiplexed led matrix , then if real data on all leds is required you need PWM it 1:3 ...
But ok continue and ask later.
