PG.9
Regarding Webserver Application
  • January 20, 2023
  • 892 views
Greetings !
I am using STM32F743 Evaluation Board for my Project . I am currently working on Firmware Upgrade over the Ethernet . Can you kindly provide any sample application / procedure for the same .
Thanks in Advance
Hello @PG.9​ ,
Check the ethernet IAP examples within STM32CubF7 MCU package​, and user guide:
  • UM1709 User manual STM32Cube Ethernet IAP example
\stm32cube_fw_f7_v1160\STM32Cube_FW_F7_V1.16.2\Projects\STM32756G_EVAL\Applications\LwIP\LwIP_IAP
 hope my answer helps you!
Imen
PG.9
PG.9Author
@Imen DAHMEN​
Thanks for your valuable information .I will try as per the references given.
Thanks,
