Problem with TIM3 Input capture with DMA
‎2024-05-29 10:31 AM
Hello everybody,
I am trying to use the TIM3 those input capture mode with DMA transfer. After buffer is full the DMA call the callback function IT. Then i execute the stop DMA function. But after this sequence, the DMA no reinitialize. I am using the Cube MX for initialize the code.
What could I be doing wrong?
I am using the STM32C011F6P6
The code:
uint16_t period_buffer[52];
HAL_TIM_IC_Start_DMA(&htim3, TIM_CHANNEL_1, (uint32_t*) period_buffer, 52);
void HAL_TIM_IC_CaptureCallback(TIM_HandleTypeDef *htim)
HAL_TIM_IC_Stop_DMA(&htim3, TIM_CHANNEL_1);
- Labels:
STM32CubeMX
‎2024-06-03 10:03 AM
I'm operating in normal mode, I had to include one more command to solve the problem:
‎2024-05-30 4:22 AM
Hello @VSchu.1,
Please share your DMA configuration
I suppose you're configuring DMA in circular mode, if you're using normal mode you need to reinitialize the DMA transfer manually in the callback function.
‎2024-05-30 4:46 AM
Hello @VSchu.1
In order to reproduce the possible issue, could you please provide more details on your setting project if possible, attach your .ioc file/configuration.
‎2024-05-30 4:53 AM
What does this mean?
What are the symptoms, and how are they different from the expected behaviour?
