Problem with interfacing with S26KL128S flash chip
G_Anastasopoulos
Dear All,
I have a board that uses the STM32U599NJH6Q as MCU and the S26KL128S is attached to the OCTOSPI1 peripheral of the said MCU.
I need to be able to erase a sector and/or a page, write data to the device and then be able to read them back.
What I am unsure of at the moment is the initialization code. Specifically, I am not sure if I need to use Octo SPI mode or Hyperbus.
Currently I am going with Octo SPI and my MX_OCTOSPI1_Init looks like this:
void MX_OCTOSPI1_Init(void)
  /* USER CODE BEGIN OCTOSPI1_Init 0 */
  /* USER CODE END OCTOSPI1_Init 0 */
  OSPIM_CfgTypeDef sOspiManagerCfg = {0};
  HAL_OSPI_DLYB_CfgTypeDef HAL_OSPI_DLYB_Cfg_Struct = {0};
  /* USER CODE BEGIN OCTOSPI1_Init 1 */
  /* USER CODE END OCTOSPI1_Init 1 */
  hospi1.Instance = OCTOSPI1;
  hospi1.Init.FifoThreshold = 4;
  hospi1.Init.DualQuad = HAL_OSPI_DUALQUAD_DISABLE;
  hospi1.Init.MemoryType = HAL_OSPI_MEMTYPE_MACRONIX;
  hospi1.Init.DeviceSize = 26;
  hospi1.Init.ChipSelectHighTime = 2;
  hospi1.Init.FreeRunningClock = HAL_OSPI_FREERUNCLK_DISABLE;
  hospi1.Init.ClockMode = HAL_OSPI_CLOCK_MODE_0;
  hospi1.Init.WrapSize = HAL_OSPI_WRAP_NOT_SUPPORTED;
  hospi1.Init.ClockPrescaler = 4;
  hospi1.Init.SampleShifting = HAL_OSPI_SAMPLE_SHIFTING_NONE;
  hospi1.Init.DelayHoldQuarterCycle = HAL_OSPI_DHQC_ENABLE;
  hospi1.Init.ChipSelectBoundary = 0;
  hospi1.Init.DelayBlockBypass = HAL_OSPI_DELAY_BLOCK_BYPASSED;
  hospi1.Init.MaxTran = 0;
  hospi1.Init.Refresh = 0;
  if (HAL_OSPI_Init(&hospi1) != HAL_OK)
    Error_Handler();
  sOspiManagerCfg.ClkPort = 1;
  sOspiManagerCfg.DQSPort = 1;
  sOspiManagerCfg.NCSPort = 1;
  sOspiManagerCfg.IOLowPort = HAL_OSPIM_IOPORT_1_LOW;
  sOspiManagerCfg.IOHighPort = HAL_OSPIM_IOPORT_1_HIGH;
  if (HAL_OSPIM_Config(&hospi1, &sOspiManagerCfg, HAL_OSPI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
    Error_Handler();
  HAL_OSPI_DLYB_Cfg_Struct.Units = 0;
  HAL_OSPI_DLYB_Cfg_Struct.PhaseSel = 0;
  if (HAL_OSPI_DLYB_SetConfig(&hospi1, &HAL_OSPI_DLYB_Cfg_Struct) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN OCTOSPI1_Init 2 */
  /* USER CODE END OCTOSPI1_Init 2 */
 In my main I am doing the following:
uint8_t ofTxBuffer[] = " **OCTOSPI Flash sample**\r\n";
int main(void)
  HAL_Init();
  MX_OCTOSPI1_Init();
// Configure the memory-mapped mode for S26KL128S
	      OSPI_MemoryMappedTypeDef mMemMappedCfg = {0};
	      // Set command to enter memory-mapped mode
	      OSPI_RegularCmdTypeDef mCommand = {0};
	      mCommand.OperationType      = HAL_OSPI_OPTYPE_COMMON_CFG;
	      mCommand.FlashId            = HAL_OSPI_FLASH_ID_1;
	      mCommand.InstructionMode    = HAL_OSPI_INSTRUCTION_1_LINE;
	      mCommand.Instruction        = 0x00; // Enter the appropriate instruction here
	      mCommand.AddressMode        = HAL_OSPI_ADDRESS_1_LINE;
	      mCommand.AddressSize        = HAL_OSPI_ADDRESS_24_BITS;
	      mCommand.Address            = 0x000000; // Start address of the flash memory
	      mCommand.DataMode           = HAL_OSPI_DATA_1_LINE;
	      mCommand.NbData             = 1;
	      mCommand.DummyCycles        = 0;
	      mCommand.DQSMode            = HAL_OSPI_DQS_DISABLE;
	      mCommand.SIOOMode           = HAL_OSPI_SIOO_INST_EVERY_CMD;
	      if (HAL_OSPI_Command(&hospi1, &mCommand, HAL_OSPI_TIMEOUT_DEFAULT_VALUE) != HAL_OK) {
	          // Initialization Error
	          Error_Handler();
	      // Configure memory-mapped mode
	      mMemMappedCfg.TimeOutActivation = HAL_OSPI_TIMEOUT_COUNTER_DISABLE;
	      if (HAL_OSPI_MemoryMapped(&hospi1, &mMemMappedCfg) != HAL_OK) {
	          Error_Handler();
	  __IO uint8_t *mem_addr;
	  mem_addr = (__IO uint8_t *)(OCTOSPI1_BASE);
	  memcpy(mem_addr, &ofTxBuffer, sizeof(ofTxBuffer));
	  uint8_t octoFLASHData[128] = {0};
	  memcpy(&octoFLASHData, mem_addr, sizeof(ofTxBuffer));
	printk("String in octo flash: %s\r\n", octoFLASHData);
  while(1){}
Once the code hits the memcpy point I am getting a hardfault.
Furthermore it is unclear to me how to proceed with actually erasing the flash.
Any help would be great.
2 REPLIES 2
KDJEM.1
Hello @G_Anastasopoulos ,
The HyperBus protocol must be used when an external HyperRAM or HyperFlash memory is connected to the STM32. For that, I recommend you to take a look at Table 7. STM32CubeMX - Configuration of OCTOSPI signals and mode IV. HyperFlash and HyperRAM memories with Multiplexed mode example and at in AN5050 and get inspired to configure the memory.
Also, I think STM32CubeU5/Projects/STM32U575I-EV/Examples/OCTOSPI/OSPI_HyperRAM_MemoryMapped at main · STMicroelectronics/STM32CubeU5 · GitHub may help you.
Thank you.
Kaouthar
I have reviewed this example. I am not sure how to bend it to make it work with my chip, as this is meant for a HyperRAM.
I have reviewed several different tickets in the forum as well, including this:
https://community.st.com/t5/stm32-mcus-products/looking-for-sample-code-for-hyperflash-erase-programming-with/td-p/126856 which appears to be the closest to my situation, but I have not managed to make it work yet.
I am not sure what is the exact problem, but based on the code that was provided on your response, I am doing these steps:
Init:
  OSPI_HyperbusCfgTypeDef sHyperBusCfg = {0};
  hospi1.Init.MemoryType = HAL_OSPI_MEMTYPE_HYPERBUS;
  hospi1.Init.DelayBlockBypass = HAL_OSPI_DELAY_BLOCK_USED;
    Error_Handler();
    Error_Handler();
  sHyperBusCfg.RWRecoveryTime = 0;
  sHyperBusCfg.AccessTime = 0;
  sHyperBusCfg.WriteZeroLatency = HAL_OSPI_NO_LATENCY_ON_WRITE;
  sHyperBusCfg.LatencyMode = HAL_OSPI_VARIABLE_LATENCY;
  if (HAL_OSPI_HyperbusCfg(&hospi1, &sHyperBusCfg, HAL_OSPI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
    Error_Handler();
    Error_Handler();
Inside the main:
int main(void)
  MX_OCTOSPI1_Init();
  OSPI_HyperbusCmdTypeDef mCommand = {0};
  mCommand.AddressSpace = HAL_OSPI_MEMORY_ADDRESS_SPACE;
  mCommand.AddressSize  = HAL_OSPI_ADDRESS_32_BITS;
  mCommand.DQSMode      = HAL_OSPI_DQS_ENABLE;
  mCommand.Address      = 0;
  if (HAL_OSPI_HyperbusCmd(&hospi1, &mCommand, HAL_OSPI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
    Error_Handler();
  mMemMappedCfg.TimeOutActivation = HAL_OSPI_TIMEOUT_COUNTER_ENABLE;
  mMemMappedCfg.TimeOutPeriod     = 0x20;
    Error_Handler();
  printk("String in octo flash: %s\r\n", octoFLASHData);memcpy(mem_addr, &ofTxBuffer, sizeof(ofTxBuffer));
When it gets to the point where to write to the flash it hard-faults.
Any ideas?
