Multiple ADC Channels (using registers)
caden013
Hello all, I am currently working on a project in which I need to sample 5 ADC channels every 50 ms. As of now, I am trying to use TIM2's TRGO (interrupt triggered every 50 ms) to trigger the conversion of a regular sequence of 5 ADC channels (PA0 - PA4) and save these values by reading the ADC's data register in the ADC IRQ (triggered by the EOC interrupt flag). For some reason, I cannot figure out why the EOC interrupt is only triggered once, at the beginning of the program. If anyone could help, I would greatly appreciate it.
I will post my code if needed (I am using the Keil uVision 5 IDE). Thanks in advance.
Stassen.C
Hello Caden013,
Could you please show us your code so that we can look at it?
Stassen
@Stassen.C wrote:
Hello Caden013,
Stassen
Yes, I will attach the ADC and Timer c files where I set their settings.
Here is where I setup their corresponding clocks (in a different file):
FUNCTION: clockSetup
INPUTS: none
OUTPUTS: none
PURPOSE: To initialize the clocks for the peripherals
void clockSetup(void)
RCC->AHB2ENR |= RCC_AHB2ENR_GPIOAEN; // enable GPIOA clock
RCC->AHB2ENR |= RCC_AHB2ENR_GPIOBEN; // enable GPIOB clock
RCC->AHB2ENR |= RCC_AHB2ENR_ADCEN; // enable ADC clock
RCC->APB1ENR1 |= RCC_APB1ENR1_TIM2EN; // enable clock for TIM2
