Is there any manual in the ST page of the differents example projects of one board?
JSanc.7
6 REPLIES 6
Olivier GALLIEN
Hi @JSanc.7​ ,
STM32CubeProjectsList.html provided in the STM32Cube Package lists all project supported per board.
Then for each example you have an associated readme.txt file explaining purpose and how to.
Is that match your request ?
Olivier
Olivier GALLIEN
For example, for 'F4, here.
Github won't serve it as html, so you have to download it as raw, and then open locally.
Thanks, Pavel. One learns something new every day.
Jan
waclawek.jan
Hi Olivier,
fancy to write an Article here, perhaps giving links to existing Cubes' apps lists, using the trick Pavel gave above?
Thanks,
@Community member​
Indeed @Community member​ , the tips given by @Pavel A.​ can likely be well used to ease access of such information.
Idea highlighted/escalated inside ST.
Thank you both.
Olivier
Olivier GALLIEN
