Integrating LittleFS in stm32L1XX project
JBamb.1
Because there are negative side effects of using FatFS in my program to write logs to an SD Card, I am trying LittleFS library with an implementation of the HAL library.
When I mount the filesystem &lfs I get a result of -84 which indicates that the fielsystem is corrupt. I made sure I tested and formatted the sd card.
I believe that my implementation of the device block operations is not complete. see attachment.
extern const struct lfs_config cfg = {
   // Block device operations
   .read = user_provided_block_device_read,
   .prog = user_provided_block_device_prog,
   .erase = user_provided_block_device_erase,
   .sync = user_provided_block_device_sync,
   // Block device configuration
   .read_size = 16,
   .prog_size = 16,
   .block_size = 4096,
   .block_count = 128,
   .cache_size = 16,
   .lookahead_size = 16,
   .block_cycles = 500,
Help will be greatly appreciated!
What is LittleFS?
I also don't think this is the right place to discuss it, you may want to try to contact its authors.
hans86
Hi JBamb,
It might be a bit late but in case somebody else is having an issue with Littlefs and finds this post I have uploaded 2 simple examples of using Littlefs with SPI and QSPI here:
https://github.com/htminuslab/STM32-LittleFS-SPI
https://github.com/htminuslab/STM32-LittleFS-QSPI
This is for a STM32H743 using HAL calls so should be relative easy to port to another STM32 family,
Hope this helps,
Hans.
