I SEND UDP PACKAGE WITH STM32 BUT THE PROTOCOL SHOWNS AS ECHO. WHY?
‎2022-11-04 7:00 AM
I'm trying to send udp data from stm to server. But when i observe in Wireshark, the protocol shown as ECHO, not UDP. What is the reason?
Ethernet
‎2022-11-10 6:33 AM
Thank you my friends. I solve the problem. The problem is due to port 7 conflict. When I changed the port number, the problem was solved.
‎2022-11-04 7:21 AM
UDP is the protocol that you are using, as opposed to TCP. "ECHO" is a particular socket/port number under both UDP and TCP.
‎2022-11-09 10:25 AM
Hello @KAnahar​ and welcome to the Community :)
Have a look at this Nx_UDP_Echo_Server example working example on STM32H735 board.
Hope this helps you.
Imen
Imen
‎2022-11-09 9:57 PM
Wireshark knows most "well known ports" (https://en.wikipedia.org/wiki/List_of_TCP_and_UDP_port_numbers), and port 7 which you are using is the "echo port".
So check the list and choose another port number, or just ignore Wireshark's "extra info".
‎2022-11-10 6:33 AM
