how to use variable in across different cores? how to debug FreeRTOS ?
  • April 3, 2025
  • 3 replies
  • 540 views
Now, I am using the NUCLEO-H755ZI-Q board,  Could you share how to solve the issue of using the same (shared) variable in across different cores?
when I try to debug the code of freertos ,It is not going to debug after it enter this line  osKernelStart(); how to debug further. how to know my code is correctly working or not. (i am useing stm32cubeIDE)
Best answer by kavyamm
Thank you for the response. For shared variable, I used hardware semaphore it is working .
for debugging the freertos ,I put a breakpoint for where I need.
Andrew Neil
Welcome to the forum.
That sounds like two separate questions. Best to keep to one question per thread.
How to write your question to maximize your chances to find a solution.
You've already seen STM32H755Zi-Q~How to share data between cores - which was answered here.
Have you studied that Application Note?
How to set up FreeRTOS debugging using STM32CubeIDE
https://www.youtube.com/watch?v=KTsrP28Gh6E
https://www.st.com/resource/en/user_manual/dm00629856.pdf#page=209
kavyammAuthorBest answer
Andrew Neil
