How to return STM32duino to Bare Metal ?
enjay
Moved from https://community.st.com/t5/stm32-mcus/stm32-arduino-stm32duino-tutorial/ta-p/49649
After you have finished the arduino project, how do you then remove everything from the MCU and use it again for normal STM32 projects in CubeMX and so on?
A full chip erase would do it.
4 REPLIES 4
enjay
Does this put the board back to its original factory settings? This is the ideal solution I am looking for. (Presumably I use Cubeprogrammer chip memory erase?)
Should do ...
enjay
Thanks for your replies.
