How to return STM32duino to Bare Metal ?
‎2024-11-26 8:34 AM - last edited on ‎2024-11-26 8:46 AM by Andrew Neil
Moved from https://community.st.com/t5/stm32-mcus/stm32-arduino-stm32duino-tutorial/ta-p/49649
After you have finished the arduino project, how do you then remove everything from the MCU and use it again for normal STM32 projects in CubeMX and so on?
Documentation
‎2024-11-26 8:47 AM
A full chip erase would do it.
‎2024-11-26 8:47 AM
‎2024-11-26 12:28 PM - edited ‎2024-11-26 12:31 PM
Does this put the board back to its original factory settings? This is the ideal solution I am looking for. (Presumably I use Cubeprogrammer chip memory erase?)
‎2024-11-27 12:55 AM
Should do ...
‎2024-11-27 1:08 AM
Thanks for your replies.
