2022-05-23 2:31 AM
I want to interface two electret microphones (stereo sound) to STM32F446 chip. I don't know how to connect it or what protocol or pins I have to use. I have found a lot of information about digital microphones but nothing on this topic.
Thanks.
2022-05-25 3:53 AM
@Andrew Neil
No, it is not an school assignment. The requierement of the use of that model is set by the company.
I am using this model of electret microphone (which meets all the freq requirements 20-20kHz): https://www.digikey.es/es/products/detail/pui-audio-inc/AOM-5024L-HD-F-R/12152286
Having capture the sounds I just will keep them in a memory. The natural sounds I want to detect are birds and mammals (humans too) (nothing about bats and ultrasounds).
I don't have any specifications about sampling (by Nyquist would be 40 kHz), number of bits or anything. In fact, I am a bit lost on this topic of sound. I just want to record sounds in a good quality. All the specifications of that electret mic are good for me.
I am considering connecting it to ADCs and manage to set the "stereo" effect in the firmware o connecting it to au audio codec (but this is what we have talked about; specifications, function and all that).
I am glad there are so many people interested on this topic and helping the community. I say sorry in advanced if any question is too basic.
Thank for your time.
2022-05-25 3:57 AM
By the way, @Andrew Neil
I have found this preamp to that mic model. It meets the impedance requirement and the voltage one too.
I know in the industry of music, preamps are use to achieve the line level to record. would it be neccesary to preamp this mic before connecting to the ADC? I guess so...
2022-05-25 4:02 AM
"if you are serious about recording stuff. Get yourself a high-quality commercial audio recorder"
Even a low-cost commercial recorder will give better results than anything using cheap electrets...
2022-05-25 4:20 AM
"The requierement of the use of that model is set by the company"
Your employer?
"I am a bit lost on this topic of sound"
Then you should really be speaking to your employer about getting some proper support and/or training in this - if it's part of your job.
"would it be neccesary to preamp this mic before connecting to the ADC?"
Again, as for *any* interfacing problem:
Almost certainly, a preamp will be required.
"I have found this preamp"
As for any component, Take a look at the support materials available on the manufacturer's website:
2022-05-25 4:27 AM
Yes, my employer.
Thank you.
