Hi everyone I am testing the "audio_record" example of the stm32h750 disco .. I found a problem that the code is blocked at the level of INIT .. can someone help pls ?
Kfoue.1
Amel NASRI
Hi @Kfoue.1​ ,
Please make sure that you are following the steps & recommendations as described in the Readme.txt file (available under STM32Cube_FW_H7\Projects\STM32H750B-DK\Examples\BSP).
-Amel
Amel NASRI
Hi @Kfoue.1​ ,
Is the issue you initially described here solved? If not, please describe with more details what you tried & where exactly are you blocked.
-Amel
