Garbled Characters Issue in Serial Port 1 with STM32CubeMX 6.13.0 and STM32Cube_FW_H7_V1.12.0
‎2024-11-30 2:42 AM - last edited on ‎2024-12-05 4:53 AM by mƎALLEm
The serial port 1 code generated by the latest STM32CubeMX 6.13.0 will print garbled characters, and using the serial port routine UART_Printf in STM32Cube_FW_H7_V1.12.0 will also print garbled characters.
It doesn't work when using the serial port routine UART_Printf in STM32Cube_FW_H7_V1.11.2. After comparison, there is a difference here. I can’t understand the function here. I will be careful whether changing it will affect other functions.
*This post has been translated from Chinese to comply with the ST Community guidelines.
- Labels:
STM32H7 Series
UART-USART
‎2024-12-05 2:56 AM - edited ‎2024-12-05 5:02 AM
Hello @zhengjianxing,
Thank you for bringing this issue to our attention.
const uint8_t D1CorePrescTable[16] = {0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 3, 4, 6, 7, 8, 9};
should be
const uint8_t D1CorePrescTable[16] = {0, 0, 0, 0, 1, 2, 3, 4, 1, 2, 3, 4, 6, 7, 8, 9}
I reported this issue internally.
Thank you for your contribution to the community.
Internal ticket number: 197431 (This is an internal tracking number and is not accessible or usable by customers).
Thank you.
Kaouthar
should be
Thank you.
Kaouthar
‎2024-12-05 5:50 AM
@zhengjianxing wrote:The serial port 1 code generated by the latest STM32CubeMX 6.13.0 will print garbled characters, and using the serial port routine UART_Printf in STM32Cube_FW_H7_V1.12.0 will also print garbled characters.
Which suggests that the baud rate is wrong:
‎2025-01-02 6:06 AM - edited ‎2025-01-02 6:08 AM
This issue is fixed in STM32Cube_FW_H7_V1.12.1 version.
Could you try to update the STM32CubeH7 and let me know if the issue is solved or not?
You can use STM32CubeMX 6.13.0 to update STM32CubeH7.
Thank you.
Kaouthar
