FMC SDRAM conflict with LWIP configuration
‎2021-03-12 2:08 AM
Hi everyone,
I have a project using STM32H723ZG interface with SDRAM IS42S16400J (via FMC) and LAN8742. If I enable both FMC and LWIP to run with FreeRTOS, my program ends up jump to hard fault handler. If either FMC or LWIP is enabled with FreeRTOS, my program will be worked fine.
This is my MPU config. I know I have done something wrong, but I don't know what it is. Please give me some advice. Thank you in advance.
void MPU_Config(void)
MPU_Region_InitTypeDef MPU_InitStruct = {0};
/* Disables the MPU */
HAL_MPU_Disable();
/** Initializes and configures the Region and the memory to be protected
MPU_InitStruct.Enable = MPU_REGION_ENABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER0;
MPU_InitStruct.BaseAddress = 0x30000000;
MPU_InitStruct.Size = MPU_REGION_SIZE_256B;
MPU_InitStruct.SubRegionDisable = 0x0;
MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
HAL_MPU_ConfigRegion(&MPU_InitStruct);
MPU_InitStruct.Number = MPU_REGION_NUMBER1;
MPU_InitStruct.BaseAddress = 0x30004000;
MPU_InitStruct.Size = MPU_REGION_SIZE_16KB;
MPU_InitStruct.IsShareable = MPU_ACCESS_SHAREABLE;
MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
MPU_InitStruct.BaseAddress = 0x60000000;
MPU_InitStruct.Size = ARM_MPU_REGION_SIZE_64KB;
MPU_InitStruct.Number = MPU_REGION_NUMBER2;
MPU_InitStruct.SubRegionDisable = 0x00;
/* Configure the MPU attributes of SDRAM as Write back, Read allocate, Write allocate */
MPU_InitStruct.BaseAddress = 0xC0000000;
MPU_InitStruct.Size = MPU_REGION_SIZE_32MB;
MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER3;
MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL1;
/* Enables the MPU */
HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
Ethernet
FMC-FSMC
FreeRTOS
STM32H7 Series
‎2021-03-12 2:11 AM
Hello @TNguy.15 Ngoc​
Thanks for your post, could you please share what type of conflict are you facing (I think with CubeMX configuration)?
Khouloud
‎2021-03-12 2:16 AM
Sorry, missed click, I mentioned my situation above, please take a look. Thanks
‎2021-03-13 3:23 AM
With ST provided code Ethernet/lwIP cannot work, especially on H7.
https://community.st.com/s/question/0D50X0000C6eNNSSQ2/bug-fixes-stm32h7-ethernet
‎2021-03-13 7:12 AM
Hi Piranha,
Thank you for your reply, really appreciate that. I'll check your advice, btw to clarify my situation:
For more details:
Case 1: FreeRTOS + LWIP => work fine
Case 2: FreeRTOS + FMC (sdram) => work fine
Case 3: FreeRTOS + FMC + LWIP => the first task cann't run, the program immediatetly jumped into hardfault handler.
I'll check again the linker and ram section. Anyway, I wonder how to move the user heap into SDRAM, so I can allocate a large dynamic memory?
Thank you.
‎2021-11-25 7:25 PM
@TNguy.15 Ngoc​ Were you able to resolve it? I am facing the same issue
‎2021-11-26 12:56 AM
MPU_Region_InitTypeDef MPU_InitStruct;
/* Disable the MPU */
HAL_MPU_Disable();
/* Configure the MPU attributes as Device not cacheable
for ETH DMA descriptors */
/* Configure the MPU attributes as Normal Non Cacheable
for LwIP RAM heap which contains the Tx buffers */
MPU_InitStruct.Size = MPU_REGION_SIZE_8MB;
/* Enable the MPU */
my MPU config
‎2021-11-26 2:45 PM
@TNguy.15 Ngoc​ If you use the SDRAM without LwIP, do you enable MPU too?
If not, it looks like configuration of MPU for LwIP above affects the region of SDRAM.
If yes, then v.v.
‎2021-11-26 5:59 PM
Currently, I'm using H743, both SDRAM and LWIP work fine. :D
‎2021-11-28 8:01 PM
@TNguy.15 Ngoc​ Thanks for sharing. I am trying to run the LWIP stack from external SDRAM and I am not able to get ping.
Khouloud ZEMMELI If I run the LWIP stack from QSPI or internal Flash memory, its working fine. Please advice. I am using H745.
