2021-01-28 12:23 PM
I am hoping to find someone who could explain or show an example of how to read data line from a MEMS microphone using PDM and output the corresponding PCM values. If anyone could help with some code examples I would be very much appreciative.
Thanks in advance
2021-01-29 12:11 PM
Hello @kcire L. ,
Welcome to the STM32 Community :)
The following resource might help to use the PDM2PCM Library to connect digital MEMS microphones :
Imen
2021-01-29 12:11 PM
Hello @kcire L. ,
Imen
2022-10-10 07:17 PM
You haven't updated these manuals for quite some time and seem to be outdated.
Do you have any intentions to add more than 1 channel in the example?
2022-10-27 12:46 AM
please also look at my problems with this lib & Keil armclang
