2021-05-10 12:57 AM
hi i am using cubemx and generated an ethernet webserver project from example on nucleo f429i board it is working with default webserver page.
However i need to use my own custom webpage , but do not know how to generate static webpage i followed some videos on youtube to generate webpages using perl makefs but is not working . I am doing somethin wrong . can anyone share any procedure how to compile a webpage any tutorial will be helpful on this ,i am using windows 10 and cubemx 5.0 ,Thank you in advance.
2021-05-20 10:23 AM
2021-06-08 4:43 AM
hi thanks ,checked the video got it working static webpage, need reference for dynamic webpage support login user.
