2019-12-23 04:12 AM
I am using Ethernet transceiver "LAN8742A-CZ-TR" for STM32F427ZIT6.
Does "STM32F427ZIT6" support the mentioned transceiver and to what pins of STM32 should i connect the RMII signals?
Thanks in advance..
2019-12-23 05:28 AM
The mentioned PHY has RMII interface and the mentioned MCU supports RMII interface.
How about the pins on which RMII signals can be routed?
