2014-08-11 09:28 AM
Is there any description of HAL library for STM32F2s.
I found the UM1725 documentation but only applies for STM32F4s.Anything similar for STM32F2s???Thanks, #stm32f2 #hal-library2014-08-11 09:46 AM
Wouldn't they be materially identical? The key differences would be the M3/M4 core, memory (size, ccm, etc) and the clock/pll, and regulator.
2014-08-11 11:14 AM
I don't know. There is a specific documentation UM1061 STM32F2xx for Standard Peripheral Library for STM32F2s, and I thought that there may be one HAL library for this chip also. but may be not.
2014-08-26 07:33 AM
Hi ed@mtrx,
You can use the UM1725 document describing the STM32CubeF4 HAL drivers, since these two devices share a lot of similarities.The STM32CubeF2 HAL drivers description document is under finalization and will be online as soon as possible.Thank you for your interest in our STM32Cube solution.With regards.2015-02-19 02:16 AM
Hi Mister White, I guess you are working on the description of the STM32F3 HAL Drivers as well? I could not find them in the ST documentation database... Kind regards Stefan
