CPU Halted while looping send data by using USB CDC
WPong.1
Hi, Everyone
I use STM32F103C8T6 send data by using USB CDC. After flash program, application can run properly but after random minute(Not exceed 15 minute) I found that CPU halted.
In while loop just blink LED and send data by USB CDC
My question is what can cause CPU halted and what I should inspect first.
Thank you for answer and sorry for my English.
1 REPLY 1
gbm
Lead III
You should inspect your code, of which we know exactly nothing.
If, by any chance, you use ST HAL-based USB device stack, sending data from the event loop causes the USB stack to hang. Search the forum for (many) topics on that matter.
