control algorithm for LED shift register
XooM
Friends, which algorithm do you use to control the LEDs in this structure? I need your ideas. I have prepared a table of the LEDs' turn on order.
ttaa
54 REPLIES 54
Hocam kendinizi bu kadar ezerek motivasyonunuzu düşürmeyin. Forumdaki yazıları okuduğumda çevirinizin biraz zayıf olduğunu ve kendinizi anlatmakta zorlandığınızı gördüm. Çeviri aracı için ChatGPT kullanabilirsiniz. Yazılım konusunda ise düşündüğünüz şekilde sorular sormaktan ziyade daha genel bir soru sorarsanız herkes sorunuzu anlayacaktır.
Translation:
Mr, Don't let yourself get demotivated by being so hard on yourself. When I read the forum posts, I saw that your translation was a bit weak and that you had difficulty explaining yourself. You can use ChatGPT for translation. As for software, if you ask a more general question rather than asking questions as you think, everyone will understand your question.
Hello, @muratsimsek ,
1- The official language is English
2- The community is also an efficient way to get answers/solutions.
Thank you
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
Thank you for your answer, you can be sure that I will pay attention.
I'm not sure that's true?
Without specific details, people can't give specific answers.
"General" soon becomes too vague to answer.
Giving a diagram is often a clearer way to convey technical details (particularly electrical connections) than text - especially when there's a language barrier.
I definitely agree with your answer. Some words within the language used can have multiple meanings, and while this can make understanding somewhat easier, as you mentioned, the language barrier makes everything more difficult. Therefore, any material that supports the problem makes it even more efficient.
