2018-12-05 10:13 AM
STM32Cube_FW_L4_V1.13.0\Drivers\CMSIS\Device\ST\STM32L4xx\Include\stm32l4r5xx.h
#define SDMMC_CLKCR_WIDBUS_Pos (14U)
#define SDMMC_CLKCR_WIDBUS_Msk (0x3UL << SDMMC_CLKCR_WIDBUS_Pos) /*!< 0x0000C000 */
#define SDMMC_CLKCR_WIDBUS SDMMC_CLKCR_WIDBUS_Msk /*!<WIDBUS[1:0] bits (Wide bus mode enable bit) */
#define SDMMC_CLKCR_WIDBUS_0 (0x1UL << SDMMC_CLKCR_WIDBUS_Pos) /*!< 0x00000800 */
#define SDMMC_CLKCR_WIDBUS_1 (0x2UL << SDMMC_CLKCR_WIDBUS_Pos) /*!< 0x00001000 */
2018-12-05 10:16 AM
Should be 0x4000 and 0x8000
2018-12-05 10:16 AM
2018-12-06 01:14 AM
Hello @Community member ,
Thank you for sharing this typo. This issue is raised internally for correction.
Kind Regards,
Imen
2018-12-06 05:46 AM
Thanks, nothing dire but stumbled over it the other day trying to make a simple decoder for the SDIO/SDMMC bit width decoder.
Not sure if this is all manually generated, or if there is a script, or combination of things.
2019-04-15 08:36 AM
Hi Clive,
The update is done in the new release of STM32CubeL4 V1.14.0
Thanks,
Imen
2019-04-15 01:26 PM
