2020-03-18 03:49 AM
When we use UART as DATA 8bits with parity, STM32F4xx_HAL_driver for UART accesses one byte beyond the specified buffer. Could you please confirm attached patch?
In stm32f4xx_hal_uart.c , there are other similar problems.
2020-04-08 03:30 PM
Hi Imen,
Thank you for your response! I look forward to good news.
2020-05-05 05:36 AM
This issue will be fixed in the coming release of Cube firmware package for all impacted series.
2020-11-26 12:55 AM
Hi @Imen DAHMEN ,
When you will release this fix?
2020-11-26 01:55 AM
Hi @KOkun.1048 ,
The fix is already implemented internally, and it will be released in the next release of STM32CubeF4 (v1.26.0).
So, keep an eye out for the coming update.
Imen
2020-11-26 01:59 AM
@Imen DAHMEN
Thank you for your response.
When STM32CubeF4 (v1.26.0) will be released?
2020-11-26 02:19 AM
Our development team is currently working on updating and improving of the STM32CubeF4 MCU package, and I can't give you an exact date at the moment regarding availability of the next release, as the date may change depending on several criteria.
Imen
