Any article for setting up a Web server (or UDP) using Azure RTOS?
Southbranch
Senior II
Is there a similar guide to this: How to create project for STM32H7 with Ethernet and LwIP stack working, but instead using Azure RTOS?
I know there are code examples in CubeMX but I would prefer a simple step-by-step guide including the CubeMX configurations
LauraCx
Thank you very much for sharing this good proposal, I will check with AzureRTOS authors and make sure it is in our backlog!
Thanks,
Laura
4 REPLIES 4
Amel NASRI
Hi @Lars Sörqvist​ ,
There is the article How to create a Thread using AzureRTOS and STM32CubeIDE?.
Is this what you are looking for? If yes, you can mark my answer as best answer.
-Amel
Southbranch
Senior II
Hi Amel,
Thanks, that is a good example of using threading with Azure ThreadX, and I have been using it.
However, I was hoping to find something about setting up a web server using Azure NetXDuo. A sort of step-by-step guide like the link I provided above.
That is a good proposal for a new article @Lars Sörqvist​ .
@Laura C.​ , do we have such article on the pipe?
Thanks,
-Amel
LauraCx
Thanks,
Laura
