2023-09-01 2:44 AM
I have generated an pwm of 1khz from timer now I want to read adc reading for once for each cycle of pwm after 50 microsecond of rising edge how to do if anyone have code please send in stm 32 .
2023-09-01 4:43 AM - edited 2023-09-01 5:07 AM
Hello Ishu,
First of all on which STM32 MCU do you wish to implement that?
You have a great video explaining the ADC and DMA here and a wiki here. This should help you.
Regards,
Stassen
2023-09-04 3:36 AM
I AM USING NUCLEO-G491RE MY SYSTEM CLOCK 96MHZ I HAVE USED ADC INTERNAL TRIGEERING TO ADC .I HAVE CONFIG AN TIMER3 FOR 400US THAT WILL TRIGGER ADC INTERNALLY ON RISING EDGE AND ADC IN INTRRUPT MODE . I HAVE USED TIMER2 FOR PWM GENERATION . BY THIS SHLOUD GET ADC VALUE ON RISIING EDGE ONLY BUT I AM GETTING VALUE ON RISING AND FALLING EDGE BOTH.
2023-09-05 1:29 AM
Hello Ishu,
You should be triggering only on rising edge for your ADC trigger if i understand well your question like below:
or else it will trigger on both rising and falling edge.
Regards,
Stassen
