[32L4R9IDISCOVERY] STM32L4R9 Discovery joystick config parameter is wrong.
In Function BSP_JOY_Init, there is a line as below:
BSP_IO_ConfigPin((RIGHT_JOY_PIN | LEFT_JOY_PIN | UP_JOY_PIN | DOWN_JOY_PIN), IO_MODE_INPUT_PU);
but IO_MODE_INPUT_PU is wrong, it should be IO_MODE_INPUT , can st fix it in the next hal lib version?
3 REPLIES 3
@Martin KJELDSEN​ sorry for @ you, but can you check this ?
Martin KJELDSEN
Chief III
Hi @周 剑强​,
I'll try to pass your correction on to the correct team; I'm only involved in TouchGFX.
/Martin
Hi @Martin KJELDSEN:
thank you for you reply.
