Wrong pins for CAN_RX and CAN_TX
NASI
I have found out that connection from transceiver pins CAN_RX and CAN_TX are connected to CAN_TX and CAN_RX.
I mean :
from CAN transceiver to stm32f105
CAN_RX -----------------------------> CAN_TX
CAN_TX------------------------------> CAN_RX
Is there anyway to fix the issue in software?
Thank you.
Javier1
Principal
If you really really reeeeeally need to, you could develop your own softCANBUS, that said i wouldnt like to be you.
The Easier choice is to modify the hardware and run the production again.
hit me up in https://www.linkedin.com/in/javiermu%C3%B1oz/
4 REPLIES 4
waclawek.jan
No.
Javier1
Principal
NASI
Ja, the easier way is to modify the hardware.
Thank you @Community member​
