What does QA mean on the nucleo board sticker?
‎2025-03-18 9:45 PM - last edited on ‎2025-03-20 6:26 AM by Andrew Neil
Theres T1 T2 T3 T4 and QA. QA is unchecked. Assuming it means Quality Assurance. Should I be worried?
- Labels:
STM32F4 Series
‎2025-03-20 6:17 AM - edited ‎2025-03-20 6:18 AM
There is no need to worry, as this situation is normal.
Practically, the Tx box is checked when the corresponding assembly phase is successfully completed. The number of phases varies by product reference. For example, T1 indicates that the product's SMT assembly was successfully completed, while T4 signifies that the final test and demo flashing were passed.
The QA box, when checked, indicates that the product has undergone a comprehensive quality inspection as part of random sampling. This check is thus optional.
In your case, the product did not undergo this random quality inspection.
‎2025-03-19 1:46 AM
No. That's common.
hth
KnarfB
‎2025-03-21 4:43 AM
QA box should be controlled by manufacturer separately. Don't worry: the board is well tested.
‎2025-03-21 8:06 AM
Thanks, that is good to know.
