Technical document organization
OlegAjax
I am trying to find schematic diagram for Nucleo board to know, where button is connected but there are many unnecessary files but where is Schematic?
This is so annoying when press Ctrl+V and your text inserted in *** block in this form, how can I insert it as plane text? Thanks
Andrew Neil
Evangelist III
Schematics are usually included in the User Manual - this will be in the 'Documentation' tab of the Product Page; eg,
https://www.st.com/en/evaluation-tools/nucleo-l073rz.html#documentation
They will be available separately in the 'CAD Resources' tab; eg,
https://www.st.com/en/evaluation-tools/nucleo-l073rz.html#cad-resources
@OlegAjax wrote:
This is so annoying when press Ctrl+V and your text inserted in *** block in this form, how can I insert it as pain text?
That's a general Windows complaint, not specific to this forum; eg, you get the same pasting into Word - it pastes the source format, rather than whatever format you have already in the document.
Chrome gives 'Paste as plain text' as a right-click option:
Failing that, paste to Notepad (or any other text-only app) first, then copy & paste to the target "rich text" application
EDIT
That will also be described in the text of the User Manual:
Also:
3 REPLIES 3
Andrew Neil
Evangelist III
EDIT
Also:
STTwo-32
Hello @OlegAjax and welcome to the ST Community 😊.
You can find all boards schematics on the CAD RESOURCES of each board for example here you can find the STM32H745I-DISCO schematics.
Best Regards.
STTwo-32
Thank you so much
