2022-06-20 07:23 AM
a) Any example part numbers for the stlink-v3minie card edge connector?
b) Is this card edge connector going to be standard for future ST-Links, or is the MIPI connector recommended?
Paul
2022-07-08 07:06 PM
I asked ST support (a) and they didn't give a recommendation. I later found it on page 10 of UM2910: reference connector part number is 009159010061911 from AVX. My team is still evaluating whether to adopt this connector because the MINIE is out of stock everywhere.
2022-07-09 08:40 PM
It is a kyocera board to board AVX10 connector which seems sold at distri like RS. 2mm pitch. A different compromise with tag connect.
2022-07-10 02:16 AM
It looks like it's not a connector but an adapter. To use it you must have the same fingers on your PCB.
2022-07-11 06:42 AM
I like the look of this "double socket card edge adapter",
but the fact it isn't available in small quantity suggests to me this was designed in for a specific big customer's production.
Guess it is still MIPI connector + ribbon cable for us.
Paul
2022-07-11 08:12 AM
2022-07-12 03:58 AM
Nikita91,
Thank you, I see them, ordering now!
Farnell == Newark in Canada
Paul
2024-04-23 09:59 PM
Hi! I need Board to Board connector for stlink V3 minie soldered to PCB. Somebody knows something like that?
