Problems setting the NUCLEO-H745ZI-Q ST-LINK/V3 for multicore debugging, as explained by AN 5286
clemente
Hello to all, I'm trying to debug my multi core application. I'm following the AN5286 indication but I'm in stall soon, at "Shareble ST-Link"!
I'm using Keil ver 5.31 and the ST-LINK is with firmware ver V3J5M2. The problem appear with one project selected at once.
When I set the "Shareable ST-Link" flag the "Unit" popup became empty and the "SW Device" show "Unexpected Error". I attached the images.
The STLink is visible:
0693W00000GWqTXQA1.pngThe SW device is not present
0693W00000GWqThQAL.pngThe popup is empty too.
0693W00000GWqTwQAL.pngPlease: is there a way to enable correctly this flag and proceed to the multi core debug?
Many thanks
Clemente
storz-as
To use the "shareable ST-Link" option, you need to install an additional SW "ST-Link Server" from ST
https://www.st.com/en/development-tools/st-link-server.html
4 REPLIES 4
storz-as
mƎALLEm
Indeed as said by @storz-as  you need to install ST-Link Server.
Hello storz-as
many thanks, I'll give it a try with the ST Link server software this evening.
Thanks SofLit
